How to mount a dual tower cpu cooler and still use 2x rams in dual channel mode?
Go to solution Solved by podkall,
8 minutes ago, EzioWar said:
i dont wanna use Aio 馃槥聽if i use cpu coolers front fan at the back of the heatsink as air pooler instead pusher will there be any issue? i'm talking about this cooler-聽Cooler Master Hyper 620S | CPU Air Cooler | Mdcomputers.in
How much for Peerless Assassin 120 SE/Phantom Spirit 120 SE/Deepcool AG620?
there will be no issue if you swap the fan side, just make sure it's facing the right way so they don't blow into each other, or like @Alinz聽said, you can move the front fan slightly higher to allow RAM clearance,
Hi, my MOBO-Gigabyte B650M DS3H, Ram - Acer Predator Vesta II 30-38-38-76 6000MHz 16gbX2
How do u guys mount a dual tower cpu cooler and still use 2x rams in dual channel mode?
My rams are 49mm high from board, so i cant have cpu cooler spread over those ram. And dual tower cpu cooler will take atleast 2 ram slots(or more) from cpu side. now for dual channel to work we at least need 2nd slot from cpu side, but dual tower cpu cooler wont allow that. Do u guys remove the fan from front of heatsink and install it at the back of heatsink? will that work and will that decrease the cooling capability of the cpu cooler and roughly by how many degrees C?
and finally are duall tower cpu coolers more effective than single tower cpu coolers in cooling at same price tag?
i'm talking about this cooler- https://mdcomputers.in/cooler-master-hyper-620s-rr-d6na-17pa-r1.html?sort=p.price&order=ASC
4 minutes ago, EzioWar said:
Do u guys remove the fan from front of heatsink and聽 install it at the back of heatsink?
I guess you could do that if your cooler allows it, or place the fan higher up. But if the heatsink part of the cooler interferes with the ram you can only make it work by having low profile ram. Check your cooler for dimensions and pick ram that fits according to the聽dimensions listed by the聽manufacturer
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
but will putting the fan back of the heatsink instead front ,聽decrease the cooling capability of the cpu cooler and roughly by how many degrees C?
It will barely matter
elephants
technically, slightly, but in reality, not enough to matter.
not much, what's your CPU? it's probably fine, besides getting heat out of the fins is as important as air intake, if not more
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
What's your CPU ?
If it's a really high power one you can go AIO Liquid cooler, if not you don't need a double tower cooler; double tower have better heat dissipation, but are only needed at 150W+; at 250W+ an AIO is required, but can be used for less
Depends on the coolers also, some have a notch on the RAM side, or may be installed but with the fan installed on the other side, yet your RAM is very tall so idk which one can fit
System : AMD R9 5900X聽/ Gigabyte聽X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18聽/聽ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /聽聽Eisbaer 280mm AIO聽(with 2xArctic P14 fans)/ 2TB Crucial T500聽 NVme +聽2TB WD SN850 NVme + 4TB Toshiba X300 HDDdrives/ Corsair RM850x PSU/聽聽Alienware AW3420DW 34"120Hz聽3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight聽mouse / Audeze Maxwell聽headphones
51 minutes ago, PDifolco said:
What's your CPU ?
R5 7600. but i wanna buy double tower to be future proof cause i'll surely upgrade my cpu in future
Then use less tall memory sticks or get an AIO...
i dont wanna use Aio 馃槥聽if i use cpu coolers front fan at the back of the heatsink as air puller instead pusher will there be any issue? i'm talking about this cooler-聽Cooler Master Hyper 620S | CPU Air Cooler | Mdcomputers.in
PC:
PCs I used before:
tyvm, which will be better cooling performance - moving the front fan 11mm higher to make room for the ram or move the front fan at the back of heatsink as an air puller?
like I said, pulling hot air out is as important as air intake, if not more (because the colder air automatically replaces the hot air with decent airflow case)
PC:
PCs I used before:
same cooling performance basically, you're rocking one of the slowest AM5 CPUs, it's not a furnace you're good either way
PC:
PCs I used before:
among those only聽Deepcool AG620 available at my place and it's 8 us $ costlier than聽Cooler Master Hyper 620S. is it worth the extra cost? please consider that i'll be using 200-250w Cpu in future with the same cooler.
what CPU? AG620 should be slightly better more or less, not much but it is slightly better
PC:
PCs I used before:
r7 or r9聽X3D
r7 or r9聽X3D
lol those aren't that hot like Intel
PC:
PCs I used before:
single tower would be enough for them? my room temp is 34c though
Im running a 7800X3D with your aforementioned setup, i didnt see any major differences in my temps after the change
System specs:
CPU:聽Ryzen 7 7800X3D [-30 PBO all core]
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Storage:聽2TB SN850X, 1TB SN850 w/ heatsink, 500GB P5 Plus (OS Storage)
Case: 5000D AIRFLOW
PSU: Corsair RM850e
PCPartPicker List:聽https://uk.pcpartpicker.com/list/QYLBh3
tyvm, wdym by "after the change" specifically
I initially had the rear fan on the front in this setup, thanks for the wonderful graphic @podkall
17 hours ago, podkall said:
But i just wanted to show off my RAM as i had purchased the RGB version but it was entirely hidden by the fan
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
tyvm
