Rgb hub help
cheersalt1
Hey, can someone help me find a rgb hub or some fans that come with a rgb hub. Basically my motherboard doesn’t have a rgb header but I want to use some rgb fans. Anything under like $170 would be good.
thanks!!
thanks!!
https://www.amazon.com/Razer-Chroma-Addressable-Controller-Compatibility/dp/B08K3TYWP6/ref=sr_1_5?sr=8-5
https://www.amazon.com/ARCTIC-P12-PWM-RGB-Pack/dp/B08Y8N5J89/ref=sr_1_1?sr=8-1
