Dual Monitor Youtube frame dropping
Solved by BetteBalterZen,
I've experienced the exact same, when using my 5120x1440@240Hz (primary display) and 3840x2160@165Hz(secondary display) monitors. The cause was Multi-Plane Overlay (MPO), a power saving feature that is enabled by default on a Windows level. If you wanna give it a try, you can disable it via a regedit:
Go to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Dwm", create DWORD called "OverlayTestMode" and give it value "00000005" - restart your system. (Windows update can revert this DWORD change I've read but never seen Update revert it on my system).
