is AMD Radeon Anti Lag Fixed for CS2?
foxbill86
Go to solution Solved by Doobeedoo,
1 hour ago, foxbill86 said:
Yeah that one is fine. Under it used to be the + too.
is AMD Radeon Anti Lag  Fixed for CS2? Will I not get ban if I turned it on? is the issue fixed or not yet?
AMD Ryzen 7 5700X3D | Gigabyte B550M DS3H Rev 1.7 | Kingston Fury X 32GB DDR4 (2X16) 2666MHz | Gigabyte RX 6800 GAMING OC 16G |
Thermalright Peerless Assassin 120 SE | 3X Rakk Maris Pro 120mm RGB Fans | Rakk Dulus Case | Gigabyte GP-P650G 650W 80+ GOLD Certified Active PFC
Lexar NM710 M.2 1TB NVMe SSD Gen 4 | Crucial MX500 500GB 3D NAND SATA
KOORUI 24E3. 24" 1080p Gaming Monitor, 165Hz Refresh Rate, IPS Panel
You mean Anti-Lag+ ? That one caused problems, so was removed from the driver. It is said to be returning soon though. The regular Anti-Lag is fine and can be enabled.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
okay, thanks brother!
