upgrade Multi-use PC Upgrade in 2024?
Solved by brob,
Upgrade the CPU, 8 concurrent threads is not really enough.
Depending on when you got the Galahad 360 AIO, you may need to get its LGA 1700 mounting kit.
CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor ($389.99 @ Newegg)
Motherboard: MSI MAG B760 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard ($169.00 @ MSI)
Total: $558.99
Generated by PCPartPicker 2024-04-09 14:31 EDT-0400
You will need isopropyl alcohol or something like https://www.arcticsilver.com/arcticlean.htm to remove old thermal compound.
