Budget (including currency): $500
Country: Canada
Games, programs or workloads that it will be used for: EA FC24, Witcher 3, League of Legends
B450 Bazooka AII motherboard
GTX 1660 GPU
16 GB DDR4 Ram
1TB HDD, 128 GB SSD NVME (or Sata not sure)
Ryzen 5 3600 6-core 3.6 GHZ
120hz refresh rate
1440p
I’ll uograde this Christmas
Need something quieter, the current set up is very loud
Edited by NewPlayer_777
https://linustechtips.com/topic/1565848-need-help-upgrading-my-pc/
Country: Canada
GTX 1660 GPU
16 GB DDR4 Ram
120hz refresh rate
1440p
Christmas is a LONG ways away.. Come back when you are close to buying parts.
By the time Christmas comes we will have had many new parts release pushing prices of older components down even more.
Hardware prices change month by month, no point in looking at anything right now.
I would say that you should get a 5700X3D, a Thermalright peerless assassin cooler to keep noise levels down as this was a complaint.
Spend the rest on a new GPU.
Edit: Damn, Canadian Rubles aint a joke! a 5700X3D is 330 bucks.
Buy a new CPU cooler and a GPU 🙂 Thats it
1 hour ago, NewPlayer_777 said:
16 GB DDR4 Ram
What speed
Primary PC:
PSU tier list
How many watts do I need?
Country: Canada
GTX 1660 GPU
16 GB DDR4 Ram
120hz refresh rate
1440p
case?
considering theres a p12 on the back of the case i assume its not the case fans so probably just cpu cooler fan but considering a p12 (max) is like 10$ might aswell buy a phantom spirit and upgrade the cooler outright
cpu wise save up some money since we arent even halfway through the year, just buy a phantom spirit and overclock the cpu for now and you can upgrade the cpu later, and if you havent already also overclock the gpu since thats just moving some sliders around in msi afterburner whilst furmark is running in the background to check for artifacts/instability
