In the image you can see that I have 4 case fans. Would I benefit from more fans? Would they improve temps? I can attach 5 extra fans, 2 on the bottom and 3 on the top. But not much air comes in from below so idk how useful would the bottom ones be.
My case is: Lian Li Lancool II Mesh ARGB
CPU: Ryzen 7600X
Cooler: Thermalright Peerless Assassin 120 SE White ARGB
Graphics Card: Asrock Steel Legend RX 7800 XT
All fans, including the 2 on the CPU cooler are: Thermalright TL-C12CW-S ARGB
https://linustechtips.com/topic/1565772-request-for-help-with-cooling/
CPU: Ryzen 7600X
Do you require more cooling?  This looks like a very good setup in terms of airflow through the case 🙂
CPU: Ryzen 7600X
You';re a little uneven for intake vs exhaust, I would add another exhaust fan at the top back.  So you have air coming from from the entire front and leaving top and back.   Not a big deal either way, just what I would do.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
If I increase my Graphics Card's Total Board Power, it's hotspot gets into 100°C+. Strangely, the VRAM temps are fine though, but increasing the TBP doesn't increase the VRAM's clocks, only the GPU's clock speed increases on it's own.
Thanks, I'll see if it improves my temps. I have a fan lying around anyways.
The fans are just not that strong. More for looks than actual performance.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
It's better than nothing 😅
And so far, looks like a top exhaust fan does help. The GPU hotspot is now at 92°C with the TBP maxed out. Previously it was at ~100°C.
6 hours ago, XRealX said:
The cables are too short to reach my fan hub 😕
they are plenty long you just need to rotate the fans to have the cables closest to the mb same with the back fan. the case has a hole at the back top left corner you can stick em thow that. the cpu fans also should have a hole above in the case.
you can put fans on the bottom too as intake
That is true. I have 3 or 4 packs of those fans, only reason I mentioned it after looking at the size of your case.
3 in & 2 out in an airflow designed case of that size should be enough, with half decent fans.
Noise may have decreased now also? (This also depends on the fans).
I’ve turned my fans around so the cables are on the blind side - Let the cable whisperer in you out 😂
Noise is the same, but I have set up a custom fan curve with Fan Control (the case fans spin up depending on what the temperature of the CPU and GPU hotspot is at.
Damn your PC looks really good 🤩
They pretty cheap and I really wanted ARGB fans lol.
Me too lol 😄
I have my sons system done up with them in a Meshify C and they work well. But the case is much smaller than the one in your pic.
Yep that'll help. IIRC, my front fans are governed by the GPU temp & the rest are governed by the CPU temp.
