rx 7900xtx model comparisons
49 minutes ago, Tetras said:TPU reviewed the Merc310 and the Pulse for the 7900 XT (I don't know how applicable it is to the XTX) and they said the Merc is loud:
But, I think you should buy the XFX just because more X is better than less X and you're buying an XTX from XFX.
Mark as Solution!
59 minutes ago, ki8aras said:hey everyone!
im looking into buying an rx 7900xtx, as im at the limit of my budget, im looking into the more budget cards
option 1: XFX Speedster MERC310 AMD Radeon™ RX 7900XTX
option 2: Sapphire Pulse Radeon RX 7900 XTX AMD 24 GB
option 3:ASRock Radeon RX 7900 XTX 24GB GDDR6 Phantom Gaming OC
option 4:ASRock Radeon RX 7900 XTX 24GB GDDR6 Taichi OC
i had a bad experience with an xfx merc card (a 5700 xt) so i'm a bit reluctant to go with it, but they may have improved since then
thanks in advance!
In terms of construction, power, and overall quality, I would pick the Nitro+ for sure! However, in your list, the Asrock Taichi OC would be the better option.
