Does I5 13600 needs aftermarket cpu bracket?
Solved by DoctorNick,
31 minutes ago, TatamiMatt said:No, its not necessary, usually the cpu bends by a few micrometers meaning the cpu cooler has bad contact with the heat spreader and doesnt cool as effectively, but for an i5 13600 not K it should generally be okay, however its usually on a case by case basis, if your temps arent great you might need to implement one, but try without first and see if temps are okay
Is millimeters not micro.
@Alan.YosephA contact frame is worth it imo, it's pretty cheap and you'll be able to get better cooling from a cheap cooler:
Thermalright LGA1700-BCF BLACK or V2
Edit: Just wanted to add this:
