How to make cooler go 100% manually?
Fat Cat11997
When im doing some benchmarks, my 7700x gets up to 90 degrees C even tho my cooler should be able to easily cool it further from what I know; the cpu specs show it produces 105W of heat at max and my cpu cooler shows it can dissapate 265W. I don't care about noise level at all so long as it means my parts will last longer, so is there any way to manually force it to go 100% in the bios?
You can't really use those metrics though as they don't take into account thermal density. The cooler's TDP usually assumes more ideal conditions, while the CPU's TDP is just the actual power draw it offers. Ryzen 7000 series chips are known for getting to 95C no matter what cooler you throw on them due to a combination of the IHS being super thick and the thermal density of the CPUs being rather high.
It won't affect part lifespan since temps will not change, and if anything it will lower the life span of the fans since they're running at a higher RPM for more of their lives.
Yeah, there will be settings somewhere in your BIOS to alter the fan curves, and you can set it to 100%. You can also just use in-Windows fan control software like MSI Center (you have an MSI board, right?) or Fan Control instead.
Set the fan speed to 100% or Full Speed, or disable automatic fan management, depending on what your BIOS says.
Caroline doesn't need to hear all this, she's a highly trained professional.
41 minutes ago, RONOTHAN## said:
TIL that there is a worthy successor to the late, great SpeedFan out there.
Bless you, kind all-seeing cat. I'd hug you if I could.
Aerocool DS are the best fans you've never tried.
Absolute wonder programme imo
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
