Using AIO fans as case fans
Solved by Needfuldoer,
What kind of screws do you have? If they're the kind that cut their own threads, just make sure the hole in the fan is only slightly smaller than the shank of the screw (between the threads). If the hole is too small, the plastic might crack or split if you force the screw into it.
You could pick up some long screws and lock nuts from the hardware store, then pass those all the way through the fans. Nobody says you have to use "PC hardware".
