I need some help with my GPU and Motherboard.
Solved by SpookyCitrus,
10 minutes ago, Nightreaper-00 said:I only have one 8 pin connector, if I use a splitter I can split one connection to the top left of my motherboard and the the other will go to the cpu cause my extension cables have a 6 + 2 and a 4 + 4 header.
Oh, wow. Ok, your power supply doesn't have a PCIE power connection at all, it's also non-modular. This power supply will not work for your build. You need to buy a new power supply that has the proper power cables.
You can not use a splitter on an 8 pin EPS(CPU) power cable to make it work with a PCIE(GPU) 8 pin. They are not compatible like that.
