Help with HP laptop
Go to solution Solved by John Reactor,
Check page 35 of this service manual
Hiya, I'm trying to upgrade my ram and storage in my laptop. Its an HP envy x360 15-ee0002na with the r7 4700U. I have opened it up and know where the ram and nvme drive are, and can see that the storage is upgradable, but the ram is completely covered so I have no idea if it is soldered or if it uses sodimms. I have looked through the HP website and a few other sources with each source saying different things. By the look of how thick and wide the shield is, i think sodimm is a reasonable guess, but want to be sure. I was wondering if anyone here knows for certain which one it is before I brick my laptop trying to find out. Also does anyone know a way to get the ram shield off easily?
Thank you for any help.
https://linustechtips.com/topic/1562564-help-with-hp-laptop/
That heatspreader is friction fit in place by all the little clips you see around its edge. Undo the screw on the M.2 part, then you should be able to lever the whole heatspreader up with a plastic spudger. (Don't use a metal screwdriver, because it's too easy to damage the PCB that way.)
Page 45 of the PDF.
https://linustechtips.com/topic/1562564-help-with-hp-laptop/#findComment-16350922
7 minutes ago, John Reactor said:
Definetly 35 not 45. Page 45 contains screen dissasemby information. SSD storage upgrade is discribed on page 33
Page 35 of the document, page 45 of the .PDF file.
They did that stupid publishing thing where the legal disclaimer pages are "numbered" with Roman numerals before the pages with Arabic numbers start, so the numbers the PDF reader reports don't match the pages on the document.
I like just typing the page number into the reader to jump to a given page, so it drives me bonkers when documents do this.
https://linustechtips.com/topic/1562564-help-with-hp-laptop/#findComment-16350937
Ah yes. I see this now. Wird.
https://linustechtips.com/topic/1562564-help-with-hp-laptop/#findComment-16350947
There is a friction fit cover over the Ram, and the NVME has a metal shield holding it in place with a couple of screws. Hope this helps.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1562564-help-with-hp-laptop/#findComment-16350962
