I know they're ment for NASes and RAID arrays but how fast should a WD Red be for a desktop boot drive? How reliable are they for constant and prolonged use rather than the high reads and the occasional write on a server?
I have one and the read speeds seem remarkably slow. Accessing an image folder (roughly 100+Mb) takes more than 30 seconds for the thumbnails to even appear. Boot is nothing really bad, under 1 minute to load from a cold boot.
For general use, it seems slow, should it be this way?
CPU: AMD FX 8320e | Mobo: Gigabyte GA‑78LMT‑USB3 | Cooler: Cooler Master Hyper n520 | RAM: 8Gb @ 1333MHz
GPU: Gigabyte GTX 1060 mITX | PSU: Antec HCG 520w | Storage: Sandisk 120GB - WD Red 1TB | Case: Modded IBM A50 sleeper
All displayed on an AOC I2421VWH
https://linustechtips.com/topic/156231-wd-red-for-desktop-drive/
It would be fine
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/156231-wd-red-for-desktop-drive/#findComment-2082586
In single drive performance, they would compare to something like a WD Green, you're better off buying a Blue or even a Black drive.
https://linustechtips.com/topic/156231-wd-red-for-desktop-drive/#findComment-2082629
It would be okay but a bit too expensive...
I already have he drive, It was the only drive they had at my local Frys that wasn't a laptop drive or a WD Black for $120.
I'm mainly asking about the weird read/ write speeds on the dive.
https://linustechtips.com/topic/156231-wd-red-for-desktop-drive/#findComment-2082633
Red is good for backup and not so good for streaming content or playing games.
https://linustechtips.com/topic/156231-wd-red-for-desktop-drive/#findComment-2082727
