Yes as long as the freezer is off or non functional, don't expect to have a freezer cool your components.
Main PC:
ASUS F1A55-M LX, AMD A6-3500, (2x2)gb Kingston HyperX Blu DDR3 1600mhz, Seagate Barracuda 500gb 7200rpm,
 Corsair CX430M, Cooler Master Elite 343, Windows 8.1 Pro 64-bit
Netbook:
Lenovo Ideapad S10-2, Intel Atom N280, (1x1)gb DDR2 667mhz, WD Scorpio Blue 250gb 5400rpm, Zorin OS 9 Lite
https://linustechtips.com/topic/156181-freezer-case/#findComment-2081901
So I had this idea and was wondering would it work.
Say you buy a freezer almost the size of you case then cut holes in the freezer for io ports and leave side panels of the case off.
Is it safe and would it work?
Thanks!
Condensation would probably blow it up
https://linustechtips.com/topic/156181-freezer-case/#findComment-2081903
and here is the freezer question again
condesation would fuck you up
if this would work, people would be using....
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/156181-freezer-case/#findComment-2081906
You'd have to cut the holes in the roof of the freezer. Also your PC will likely melt some of the frost/ice in there, meaning water will be dripping all over your components. In short, probably not.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/156181-freezer-case/#findComment-2081909
If you can squeeze a dehumidifier in there as well as good airflow .. it could work
I think it will be better to have a open test bench outside i the snow than in a freezer...
condensation would propably be a little bitch about it
Thanks guys and so it seems that condensation would be a problem hahaha
https://linustechtips.com/topic/156181-freezer-case/#findComment-2082190
https://linustechtips.com/topic/156181-freezer-case/#findComment-2082205
hahaha I just saw your Alienware and dang that's nice how is gaming on it as much as people hate on alienware they shouldn't 1. Sweet aesthetics 2.They have 3D laptops 3.The current Alienware 18 is the only laptop I've seen with an 880m in SLI
https://linustechtips.com/topic/156181-freezer-case/#findComment-2082282
I love it, I am hoping to upgrade to the new one soon. Mine is getting a little slow, though it is fine for 1080p stuff, the cards are equivalent to 2 desktop 7850s in crossfire (r9 270 are the modern re brand I believe, similar anyway)
Well I am somebody that finds value in alienware and apple... sue me, I am willing to pay for premium products, it seems most people on here are not. If I can afford it, why not get something premium
https://linustechtips.com/topic/156181-freezer-case/#findComment-2082290
Exactly that sounds awesome hope you get a sweet new alienware
https://linustechtips.com/topic/156181-freezer-case/#findComment-2082318
probably will. It is quite heavy though so not good for portability, fine for taking to fiends houses/LANs etc >< hence the little laptop you see in my sig which I use for travelling
https://linustechtips.com/topic/156181-freezer-case/#findComment-2082324
O gotchya yea most laptops with high end hardware are bulky the one upside is it feels substantial
https://linustechtips.com/topic/156181-freezer-case/#findComment-2082339
Yes they should. Dell is the devils favorite company.
They lie, they will remove warranty if you do ANYTHING what so ever. They are overpriced for whats in it. Have fun talking to a guy in india if you have a problem. I don't trust them one tiny bit when it comes to quality. There have been so many cases over the years where their quality has been severely lacking.
Oh and they weight more than most desktops.
The Mistress: Case: Corsair 760t   CPU:  Intel Core i7-4790K 4GHz(stock speed at the moment) - GPU: MSI 970 - MOBO: MSI Z97 Gaming 5 - RAM: Crucial Ballistic Sport 1600MHZ CL9 - PSU: Corsair AX760  - STORAGE: 128Gb Samsung EVO SSD/ 1TB WD Blue/Several older WD blacks.
https://linustechtips.com/topic/156181-freezer-case/#findComment-2082950
