Is 650w psu enough for rtx 4060 ti/3060 ti??
Amzadd
Posted (edited)
also is it enough for rtx 4070??
Corsair Cv 650w 80 + bronze
ryzen 7 7700
air cooler
Asus tuf b650 plus wifi
32 gb 6000 mhz ddr5 ram..
1 tb m.2 ssd
2 tb hard disk
Edited by Amzadd
Depends on the rest of the system. All components use power, not just the gpu.
ryzen 7 7700
air cooler
1 tb m.2 ssd
2 tb hard disk
ryzen 7 7700
air cooler
1 tb m.2 ssd
2 tb hard disk
Yes. a 650w will be enough for that system even with an rtx 4070 🙂
The 7700 draws around 65-80w and the rtx 4070 draws a maximum of 200w.
Say 150w for the rest of the system you are still only at 400-420w of maximum power if everything is under 100% load.  No problem with a 650w 🙂
I would feel comfortable using a 650w with my own 7700x and RTx 4080.
Why are you useing a 4060 with a 7700?
He could have gotten a 7600x and saved 90 dollars. Plus the 7600x is still a very capable cpu.
Sure, he could have. The 7600x is only 56 dollars cheaper than the 7700 non X however.
I have the 7700x and would never trade it for the 7600x even though I only game, I like having a bit more cores.
My gaming habbits are very demanding.
That being said, the 7600 non X is probably my favorite gaming CPU on the market right now! It packs a massive punch for its price and it even comes with a stock cooler.
But if one can afford better, go for it.
Why...is there anything wrong?
