Memory upgrade: I have 16GB(2x8) and i need another 16GB
Solved by Dedayog,
1 minute ago, Gorklar said:Should i buy another 2x8GB kit and playce next to my original rams, or should i buy a new 2x16GB kit? (DDR4)
My ram CL17 timing, if i buy a new but CL16 timing, is it cause a problem or can i setup the same CL17 timing?
I have the following stuff:
Motherboard: Asus Tug Gaming X570-Plus
Memory: Kingston HyperX Predator HX436C17PB4K2/16
Processor: AMD Ryzen 5 5600X
Thank you
(Sorry for my english)
It'll run the CL17 naturally, as it al runs as slow as the slowest stick.
Just get another 2x8 of the same stuff. Ryzen 5600 can run 4 sticks without issue. I do it.
