Weird noise from DC LS720 pump
18 minutes ago, Muffin. said:Okay. Sorry for the long delay, I was just waiting for my pwm/argb hub to arrive and then work with the PC rather than having to work with it 2 times (pump, then mess with hub).Â
To the point -> I guess it's maybe better? I guess the sound now disappears a bit quicker than it did, but it still comes up randomly and then goes away after secs.
I managed to capture the sound it makes and also a pic how I have it mounted now.
- Pic:
- Video (better on headphones, the sound appears at around 6sec. Some talking in the background, sorry, but for a split sec you can hear how the sound appears there):Â https://streamable.com/hne2zr
- Also for others I can suggest removing the pre-applied thermal paste and apply new one on your own. I ain't no pro, but this doesn't look like enough:
There's no need to reapply the paste. You don't need a lot - you just need the whole surface of the CPU to be covered with a thin layer that fills any gaps. That looks really good, and even pressure, too.
Â
I barely heard anything with 100% volume, but around 7 seconds I heard a mild noise that sounds like the impeller. Nothing to worry about. Good job!
