2 x Gaming PC Build for max 1200Euro (600 Each)
On 2/17/2024 at 2:08 PM, PC HEROES said:Hello... I was able to put together a Build List for a PC where all the Parts come from Amazon. Since you will need 2 PCs they will both be identical unlike the 2 older PCs. Please have a look and let me know what you think. I will be happy to answer any of your questions.
This new PC will be able to do most games on 1080p ranging from Low to high Graphics Settings and will pair really well with the Monitors that you already have.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
https://de.pcpartpicker.com/list/yjqfCd
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core Processor (€97.90 @ Amazon Deutschland)
Motherboard: Asus TUF GAMING B550M-PLUS WIFI II Micro ATX AM4 Motherboard (€130.00 @ Amazon Deutschland)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (€39.99 @ Amazon Deutschland)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€63.90 @ Amazon Deutschland)
Video Card: XFX GTR XXX Radeon RX 580 8 GB Video Card (€149.00 @ Amazon Deutschland)
Case: Tecware Forge M MicroATX Mini Tower Case (€45.99 @ Amazon Deutschland)
Power Supply: EVGA 500 BQ 500 W 80+ Bronze Certified Semi-modular ATX Power Supply (€65.75 @ Amazon Deutschland)
Total: €592.53
Couple of things there:
First: The Kingston NV2 drive is a gambler's drive. You don't know what you will get exactly when you buy it. It's offered with different controllers and memory chips and its performance and reliability can range from "awesome for the money" to "complete garbage; would've been better with an old school SATA SSD with DRAM".
Second: €130 for B550 mobo when it's gonna run the slowest Ryzen 5000 CPU is a complete overkill. With what is basically a 35W processor, it can safely drop down to B450M mobo like the Asus Prime B450M-A II and still be more than enough.
Third: RX 580 in 2024 ??? The 6650XT is just €100 more, but drags it all across the ring.
And fourth and final - 500W PSU??? Yes it's a low power system, but for the same money a 650W is a no-brainer.
If he wants to scrape the bottom of the barrel with brand new stuff, there is a better way:
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core Processor (€92.90 @ Alza)
Motherboard: Asus Prime B450M-A II Micro ATX AM4 Motherboard (€55.83 @ Amazon Deutschland)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (€37.90 @ Alza)
Storage: TEAMGROUP MP33 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (€62.33 @ Galaxus)
Video Card: XFX Speedster SWFT 210 Core Radeon RX 6650 XT 8 GB Video Card (€257.99 @ Mindfactory)
Case: Zalman S2 ATX Mid Tower Case (€38.90 @ Alza)
Power Supply: EVGA 650 BQ 650 W 80+ Bronze Certified Semi-modular ATX Power Supply (€65.90 @ Alza)
Total: €611.75
Generated by PCPartPicker 2024-02-18 18:18 CET+0100
However, i still would preffer the 2nd hand route with B550+5600x+6700XT.
