Can it fit?
Go to solution Solved by Agall,
25 minutes ago, filpo said:
As part of moving my system to a smaller form factor I’ve chosen the nr200p case (huge thanks to @Agall) and I’ve just got the case today, planning on buying the new mobo and psu. One thing I was wondering is if a cooler like the thermal right Phantom Spirit 120 SE or thermalright PA120 SE can fit. Pcpp says they can’t as when I try to put in an nr200p with a thermal right PA120 SE or Phantom Spirit it just won’t have it but I was looking over the manual and saw the max cpu cooler height (pic below). It said 155mm and I distinctly remember the PA120 SE and especially the Phantom Spirit fitting in that spec (pa120 se is 155 and phantom spirit is 154), but pcpp wouldn’t accept it. So I was wondering if either of these will actually fit and pcpp’s just being silly or it’s the other way around.
Another idea could be the side panel radiator/fan mount reducing the cpu cooler max height and if anyone knows the answer your comments are appreciated. Thanks!
from the manual:
IIRC, a major advantage of the NR200P versus the Ncase M1 (as a buyer of both) was the extra thickness that allowed you to use certain 120mm tower coolers like the PA SE versus being stuck with 92mm coolers like the U9S.
I wouldn't use the glass side panel unless you really want to, since the GPU will happily exhaust through the mesh side panel rather than dumping all that heat into the CPU like it would with a TG panel.
I have neither of these parts available on hand to test it for you though, since the PA SE I have is in an actively working machine and the NR200P I have is in a random box in my garage awaiting to be moved to a storage unit for the ~3 weeks I'll be homeless between house closing dates.
from the manual:
Edited by filpo
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1557109-can-it-fit/
from the manual:
I would trust the manual more then PCPP.
https://linustechtips.com/topic/1557109-can-it-fit/#findComment-16313599
from the manual:
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1557109-can-it-fit/#findComment-16313613
I was planning to because it would’ve been on my desk but now I’ve changed my mind so I’m going to put it on the floor with the mesh panel. Thanks
Great to hear. It’s much smaller than my old 4000D 😄
25 minutes ago, Failure 101 said:
I would trust the manual more than PCPP.
Got it 👍
Total: £1040.95
https://linustechtips.com/topic/1557109-can-it-fit/#findComment-16313626
