Supermicro Server not powering on (no LED or beep) when PCIE is connected
28 minutes ago, Neido said:A few months ago I bought a Supermicro tower server. I have been using 4 (+1 boot) SATA SSD drives and running TrueNAS Scale on it.
Just now I switched out the SATA cabels that were connected directly to the motherboard to an HBA. And now the server won't turn on.
And I don't mean it wont POST or BOOT. It won't even power on.
When I disconnect the HBA and the PCIE riser, it POSTS fine. Even if I only connect the riser by itself with nothing at the other end of it, same issue.
I tried two different risers and same thing happens.
The HBA is a Broadcom 9300-16i, but since the problem happens even without it connected I don't think it's an issue.
Is it just some BIOS setting I am missing? Is my motherboard faulty?
Here are the specs:
Mainboard: Supermicro X9DRW-IF
CPU: 2 x Intel Xeon 2680 V2
RAM: 16 x 16 GB DDR3 1333 MHz ECC
PSU: 500 W (Bronze)
They use a none-standard riser:
https://www.supermicro.com/support/faqs/faq.cfm?faq=13674
QuoteIt doesn't work because, although it is a x16 PCIe slot, but the pin definition is different from standard PCIe slot. We defined the pin assignment for our W platforms. The riser card for this slot is RSC-R2UW-2E8R or RSC-R1UW-E8R.
