Wifi endoscope with changed camera
Solved by jaslion,
Make it come out of the tubestick through a hole and then stick it back in once it makes the bend?
Basically make the end a bit wide or whatever to accomodate the length?
As for usb to work. If the wifi usb thingy is literally just a usb signal over wifi then well most anything will work. If its a video feed you'll have to check what feed the camera outputs and what thr wifi stick accepts. Multiple available standards for this so as long as one matches it'll probably work
