I'm more than on a budget. While looking for cheaper alternatives i came across a series of blogs and videos about using workstation as entry level in gaming. That's what i am pretty much looking for, enough to play at minimum or medium graphics without spending too much, and for me too much is more than 200/250€. I found the HP z420 (around 150€ on eBay) as an ideal candidate but i would like to know if any of you have similar alternatives that may perform equally or even better at the same price. Note that i am going to upgrade gpu and ram, even cpu if i stay in range with the budget (everything is going to be second hand :P)
Let me know :D
https://linustechtips.com/topic/1554117-workstation-as-gaming-entry-level/
The Z420 isn't bad if it's a newer at least 6th gen i5 or higher, I've seen those for within your budget pretty regularly. Do you know which CPU this particular Z420 has in it. Also is this the SFF(small form factor) version? If it is it may not have a PCIE power connector coming off of the power supply so you will need to get a dedicated GPU that doesn't require external power. Also if it is the SFF version you will need to purchase a low profile GPU as it will not support full size cards.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
CPU Its a Intel Xeon E5 1620 v2. As for now i saw different builds with GT1030, GTX970, GTX760
I recommend buying the GPU separately,
A RX 480 8GB is a good entry option.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
Not worth, I wouldn't go for an older Xeon like that. Unless you're looking to play PC specific games, with your budget, a console may be a better option or saving up a little more and getting something actually worth the money.
