Posted January 17 Hi, i am having trouble with my headset mic picking up the loud game sounds (like others speaking or shooting), i believe it is because they are fiscally attached, i was planning to buy a separate dynamic mic like the podmic with an audio interface, or something cheaper like a usb one like the Q2U but since i don't wanna waste my many in something that isn't gonna fix the issue, and ending not using it, came here to ask if someone knows exactly what the problem could be and how to fix it, or if what i set will fix it. My headset is the cooler master MH751 Also if the sound is travelling through the body of the headset to the mic, are there other headsets that don't have that problem? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 18 There is a high likelihood that it is the cable and connector being a naturally flawed design. The issue is that the mic and headphones share a ground so at higher volumes it feeds back or rather bleeds through the ground. This is what I've been told but I've experienced it multiple times. I have a feeling that it could be fixed with a better cable and have talked to the people at hart audio cables about making me a custom cable to see if it solves the problem. But the fool proof way is to ditch the 4-pole/trrs connection entirely and use a completely separate mic whether that's with something like an antlion modmic, usb stand alone mic or an xlr mic with an interface. Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus - Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200 Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 - *Hifiman R7dx On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2 DAC S.M.S.L SU-9 Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116 Class-D amp Topping A70 Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube) Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7 Audio Interface Rode AI-1 Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions Cables Hart Audio Cables - Periapt Audio Cables Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A) *given as gift or out of commission Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 18 Author ohhh, that is new info, so if sharing ground is the reason, there is no headset mic combo that will be immune to that, since the jack doesn't has a second ground for the mic, so no sharing it is not an option, or? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 19 12 hours ago, pani_alex said: ohhh, that is new info, so if sharing ground is the reason, there is no headset mic combo that will be immune to that, since the jack doesn't has a second ground for the mic, so no sharing it is not an option, or? I don't know all of the ins and outs of this phenomena but it is inherent with the cable design yes. I would imagine that a higher quality cable could reduce this issue but I haven't tested it. The only way to make sure it doesn't happen is to have two separate systems. Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus - Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200 Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 - *Hifiman R7dx On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2 DAC S.M.S.L SU-9 Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116 Class-D amp Topping A70 Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube) Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7 Audio Interface Rode AI-1 Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions Cables Hart Audio Cables - Periapt Audio Cables Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A) *given as gift or out of commission Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
