I need help with my pc.
Solved by esukunzu,
Okay, now it works i just had to do some twinkling in the cmd
2 minutes ago, Chapunna said:Delete all partitions and it should work
i just literally saw your comment even though its already fixed now. But thanks for all of your help its actually really helpful to others!
2 minutes ago, Chapunna said:You have to convert disk drive from gpt to mbr via cmd, press shift + f10 and then look videos on youtube you will find solution
(i just saw this as i was writing that but this didn't work i've tried it but good effort!)
Thanks for your work!!
esukunzu off-
