help Synology NAS Raid Issues: Help needed
Solved by Kid.Lazer,
I just added this edit when you replied.
QuoteYou might be able to pull your new 4TB drive, then reconfigure the volume to "basic", and then reinstall your new drive.
Give it a try and see what happens. If this data is critical, it should be backed up externally regardless.
Edit: found this on reddit:
QuoteDeactivate a drive, create a new jbod storage pool 2 on your inactive drive, create a new volume 2 on your jbod storage pool, move your shared folders from volume 1 to volume 2, delete volume 1, delete storage pool 1, add your unused drive to storage pool 2, expand volume 2.
