Thermaltake V1 - RTX 3060 12 GB 2x - concerned with width
From the look of this screenshot (included at end) the extra 1.5mm are on the side of the card that shouldnt matter. The V1 says it can take weird measurement (or standard 2 slot), so id wager its saying that the card cant drop below its 2 slots at that will hit the sides of the case but in this GPUs case the extra 1.5mm looks like its here;
That being said, if its bigger than listed spec, its always going to be a risk to buy
EDIT: The gigabyte windforce OC 12gb from microcentre is $10 cheaper, 1mm thinner and clocked at 30MHz higher if that suits your need better?
Though it doesnt fit in the inner chassis as its longer but it fits in the outer chassis so shouldnt be any issue
EDIT 2: Microcentres page is wrong after a little bit of digging, the gigabyte windforce OC card is showing stats for the gaming OC
The true sepcs for it is 15MHz lower clock speed and sizing is as follows;
L=198 W=121 H=39 mm
So its quite a bit smaller than the MSI card
