First PC need help thanks!
1 minute ago, Chickooj said:So this one is better and just swap the storage and add the monitor that @Dedayog recommended?
it's cheaper, here's what the build would be good with, you could swap the ram with similar speed if you find cheaper or better looking for you
as for the monitor, it's good to ask in Displays sub-topic about that, but if you're not a color sensitive person, all you need to look out for is specs, and maybe the reviews: ( @Dedayog's monitor sounds decent spec wise, but be assured he just found a random 1440p 1ms 180Hz monitor and slapped it on the list)
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($399.00 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($33.90 @ Amazon)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard ($149.99 @ Amazon)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($92.97 @ Amazon)
Storage: Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($129.99 @ Adorama)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XT 20 GB Video Card ($759.99 @ Newegg)
Case: Fractal Design Pop Mini Air MicroATX Mid Tower Case ($89.99 @ B&H)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.99 @ Newegg)
Custom: 1ms response 1440p 144+Hz ($199.00)
Total: $1974.82
Generated by PCPartPicker 2024-01-04 10:58 EST-0500
