Why would you consider buying a non working motherboard if you cant even look up error codes yourself?
https://linustechtips.com/topic/1550326-asrock-help/#findComment-16267054
4 minutes ago, LoricaSefu said:
i want to buy a used Asrock mobo
Which one? They've made a lot of motherboards, and ASRock is arguably the least consistent motherboard manufacturer out there with the most variance from board to board.
Also if it beeps when booting and doesn't boot, don't buy it for anything but a wall decoration.
https://linustechtips.com/topic/1550326-asrock-help/#findComment-16267055
2 minutes ago, LoricaSefu said:
Hi guys, i want to buy a used Asrock mobo, and the seller says it does 7 beeps when he starts it, what does that mean? and how can that be fixed?
For AMI BIOS',
Quote
7 short Virtual mode processor exception error The CPU has generated an exception error because of a fault in the CPU or motherboard circuitry
If it's too good to be true for the motherboard, it's probably defective.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1550326-asrock-help/#findComment-16267056
it does 7 beeps, and then does not turn on? That means it's broken. Get yourself a different one.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1550326-asrock-help/#findComment-16267057
The guy tested it without a cpu, I dont know guys, im no pro in pcs, and i have barely any money, and i try to build myself one, slowly, part with part
https://linustechtips.com/topic/1550326-asrock-help/#findComment-16267085
lol what
Per what @CommanderAlex helpfully dug up:
Quote
long story short: the seller tested the motherboard with no CPU, and got a CPU error, wonderful. But please, don't buy products from sellers that don't properly test their products before selling. The only proper motherboard to buy is one that can most definitely fully boot up, with a CPU installed.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1550326-asrock-help/#findComment-16267088
So the seller doesn't know what they are doing, or they are hiding something. There are lots of alarm bells here. Either way, it sounds like this is a bad idea. I'd skip this one. Even on a tight budget, have some patience and wait for the right deal to come to you. You'll find a working board.
https://linustechtips.com/topic/1550326-asrock-help/#findComment-16267090
