Is 35C while idle using AIO normal? (Full load 93C).
Arthenium1
I have Ryzen 5 4500 (i know it's not that good). it's idling at 35C sometimes 38C using corsair h100i (the first version). and on full load using cinebench it's reaching 93C. is it normal, or should i start seraching for new AIO (or use my wraith prism cooler).
Depends on your Ambient temps for 28C-30C its good idle temp. Below 25C ambient it's a bit on the higher side but still decent.
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
Just now, da na said:
35 at idle is alright, but that 93 under load for a Ryzen 5 suggests poor mounting pressure or not enough thermal paste.
Ditto on this, was going to say the same thing, cooling a Ryzen 5 isn't a very tall order. If mounting pressure/paste aren't an issue then the AIO is at the end of it's life.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
Given the h100i has been around a little while, how recent is it's installation on this machine?
Are you using the correct mounting hardware to ensure a good contact?
How longer after installing the cooler, did you notice these results? Were the results good with the same AIO in the past?
35c idle is pretty low, my cpu idles on at around 40-50, but it also never goes above 65 in gaming, and 75 under stress testing.
the ambient temp is 25C
the cooler is very recent. but the rest of the system is already 4 months old. Never test it with another AIO. The contact is good, i've applied nice pressure on the cpu.
considering the AIO is more than 4 years old....
Should i change the coolant?
Then 35C is fine.
Is the cooler compatible with AM4 as per the box specifications? AM3+ Air Coolers are same specs as AM4 but some AIO's have a slight variation.
  • Deepcool AK620 WH
  • Deepcool CK500 WH
As far as I'm aware that's not possible on units like yours. At least not without dismantling the pump/block, which can be a royal pain in the ass and can always pose the risk of leaking if you dont torque it down perfectly.
Main rig on profile
VAULT - File Server
yes that's the risk that i've wouldn't take. i am afraid that the seal in the AIO is not in prime condition.
15 minutes ago, Techreprise said:
Then 35C is fine.
the previous owner (my cousin) is using the AM4 too Ryzen 7 2700X.
I don't blame you. I consider myself fairly skilled and careful and that's not even something I care to fuck with... And this is coming from someone who takes apart power supplies minutes after use.
Ultimately you may just want to consider getting an air cooler. Less bits to go wrong, after all.
Main rig on profile
VAULT - File Server
