Suddenly my pc just turned off, i tested the psu using a paperclip was working. When i plugged everything out, i noticed only when plugging in the cpu 8 pin connector would none of the fans spin. So is it a connector,motherboard or cpu issue?
Attached is a link to all the fans spinning.
cheers for the help!
https://linustechtips.com/topic/1548778-help-pc-wont-turn-on/
If I understand you right, the fans spin when you don't have CPU 8pin plugged in? or?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1548778-help-pc-wont-turn-on/#findComment-16257328
7 minutes ago, nabiltan said:
They spin when the 8 pin is NOT plugged in
does it refuse to turn on after the 8 pin is plugged?
current PC:
https://linustechtips.com/topic/1548778-help-pc-wont-turn-on/#findComment-16257370
