Strange speed issue with switch
Solved by Needfuldoer,
2 minutes ago, ComradeBard said:Here you go
Thanks.
I still think the PC's network cable is the prime suspect. Try swapping its cable with the PS5's, if they'll both reach.
Does your PC have a 2.5 gig NIC, or just regular Gigabit? You could try hard setting it to use gigabit, but then you might see the connection drop entirely instead of falling back to 100 meg.
