Currently, I am looking for a case to transplant my current build into. I have been using the H710 with a custom wrap job on the case. However, I recently upgrade to 7800x3D and 7900xt and the Red and Black color scheme clashes with the colors of the hardware inside, mostly monochromatic. I was wondering if anyone on this lovely forum had suggestions on a case one preferably with a removable motherboard tray as I am planning on painting the interior white. Id like to keep it at a mid tower but im not against a full tower. I am using the ATX formfactor
Thanks in advance -LB
https://linustechtips.com/topic/1548159-pc-case-recommendations-advice/
Lian Li O11 Dynamic XL
Be Quiet Silent base, Dark Base and dark base pro (I think it's called)
Cooler master cosmos (Expensive)
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
cases dont have removable mb trays and the ones that do cost alot.
1 hour ago, Guardian452Bob said:
Quite a shame that something that used to be a pretty standard feature is now relegated to the rare and expensive.
theres alot of things that we dont see like hinged doors.
