Need help deciding which CPU to get
Solved by brob,
You may want to use the K variant (as opposed to the KF) to retain Quicksync. The feature may prove useful for video encoding should you get into video editing. By all accounts it is still better than NVEC encoding.
Did you consider the i5-14600K or i7-14700K?
The PSU is Tier B. It's often confused with the GF 3 which is Tier A.
Featured Topics
Spencer The Mid ·
Posted in Hobby Electronics0 -
Eurimeee ·
Posted in Troubleshooting1 -
2
2
monkk ·
Posted in Networking3 -
1
