Surround sound for my projector
Skyblock
Hello! I’m looking for speakers used preferred for my projector thank you!
You're going to get zero helpful replies with the utter lack of information you've provided.
What projector? What model? If it's a model we cannot find a manual for, can you provide pictures of the inputs and outputs?
Bedroom? Living room? Dedicated theater room?
What is your budget? $200? $5000?
What country? USA?
What retailers can you use?
Are you looking for true 5.1/7.1/Atmos surround sound?
  • Or are you just looking for a great, loud experience that an excellent 2.1 setup can easily provide?
Wired? Wireless?
You want a simple home theater kit that most manufacturers provide?
Do you want opinions of what receiver, speaker, subwoofer, etc. to choose?
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
What's you budget?
Do you already have an AV Amp / Receiver?
How big is the room you are trying to fill?
Do you need a Sub?
5.1 / 7.1 / Atmos?
Bedroom PC - Lian-Li O11 XL Evo - Intel Core i5 13600k @ 5.4P / 4.4EGhz -  MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - Gigabyte RTX 4090 - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Living Room PC - Hyte Y60 - Intel Core i9 9900k @ 5Ghz -  MSI Meg Ace Z390 Mobo - 16GB Ram - Palit RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i7 8086k @ 5.1Ghz -  Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA RTX 2080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office - Thermaltake Tower 100 - Intel Core i7 8700K @ 5.1Ghz - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA GTX 1080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Annex - Corsair 250D - Intel Core i7 3770k - Asus P8Z77 I Delux Mobo - 16GB Ram - EVGA GTX 980ti - 256GB Corsair SSD - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Office - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 15TB Storage Server
Living Room AV Setup 5.1.4 - Yamaha RX-A2060 - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Yamaha RX-A1070 - 5 x Monitor Audio C265s (2 Zones)
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
Any budget and I need everything its about the size of your average bed room if that makes sense 1080 60hz projector
