Uk Power Cords Clevo X170km-g
Solved by ThatTrainGuy,
31 minutes ago, Rolling2405 said:I'm not sure, honestly. I have the US power cords and power bricks since I'm from the US. I'm going on a trip to the UK next year in July and I want to have official UK power accessories so I don't have to use any adapters.
Alright I understand.
If you have the power bricks, all you need is the power cords.
Standard 3 pin/prong 'kettle' leads is what you need.
Power cords for Clevo's in the UK generally come with 5/10 amp fuses installed also, although if you can't acquire those 13 amps one's will suffice.
You can get them from the usual places, Ebay, AliExpress etc....
