suffocation advice
Go to solution Solved by Somerandomtechyboi,
42 minutes ago, jaslion said:
Also speaking of 4060 check if a rx6700 or 6700xt is available. Normall same pricr but faster and more vram which is getting quite important
Add to that used 3070/3080 or 6800(xt)
And also 12600k(f) over the 13400 considering there are some dirt cheap z690 boards and also just the higher stock boost freq + not locked imc volt if not going for a z690 board
Well seeing as you don't list what case it is or provide any images showing how the airflow is actually set up how did you want us to answer that. I could take a wild shot in the dark and just say no if that's what you'd like to hear
https://linustechtips.com/topic/1544219-suffocation-advice/#findComment-16226554
5 minutes ago, geoffery said:
I am building a new pc i have a rog case from a prebuilt and it has a hard front panel and i was wondering if it would suffocate a 4060 and 13400f?
They're not very warm parts so it should be fine
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1544219-suffocation-advice/#findComment-16226556
Leave the side panel off and any case will have enough airflow for any parts!
Can you post a photo of the case, if you can't identify it?
https://linustechtips.com/topic/1544219-suffocation-advice/#findComment-16226568
Pics?
https://www.nl.fnac.be/ASUS-G10CE-51140F202W-BE-90PF02T2-M00J40/a16589352
Is it like this stupid thing?
Make sure you have something better than the stock intel cooler
And yeah thid case is restrictive af leave the side panel off and you're fine
https://linustechtips.com/topic/1544219-suffocation-advice/#findComment-16226579
6 minutes ago, jaslion said:
Pics?
that is the same case so thank you for the info
I built My computer.
https://linustechtips.com/topic/1544219-suffocation-advice/#findComment-16226584
https://linustechtips.com/topic/1544219-suffocation-advice/#findComment-16226607
