Need help with finding 48GB Ram sticks for my laptop
Evyatar
Hello.
I have a workstation laptop and I'm looking for more ram for it.
The model is Lenovo Thinkpad P16 Gen 2.
It currently has 128gb of ram but from Lenovo's site I've found that it supports up to 192gb, see the attached PDF:
https://psref.lenovo.com/syspool/Sys/PDF/ThinkPad/ThinkPad_P16_Gen_2/ThinkPad_P16_Gen_2_Spec.pdf
Memory Max
Memory Up to 192GB (4x 48GB DDR5 SO-DIMM)
I'm looking for a part number for 48GB DDR5 ram sticks that support my device.
I need to find a part number or some company that sells these ram sticks.
Could someone help me with it, please?
Contacted my supplier and they have no idea.
Thank you...
Add me on Steam: http://steamcommunity.com/id/Evyalectric/
OR add me to your friends list on GTA V - Wiser94
8 minutes ago, Patrix87 said:
Man, you're wonderful.
Thank you so much!!!!
Do keep in mind that mutliple kits arent guaranteed to work togheter or fully work togeter at their rated speeds.
Yes, I've read that, really shameful but I need the space not the speed so I'm fine with it.
