Coiled cables for sennheiser HD 560s
Jaipat
Hi,
I am looking for a coiled cable that would fit the sennheiser hd560s. If you have any recommendations please let me know.
Thanks.
7 minutes ago, Jaipat said:
Hi,
Thanks.
I would contact Hart Audio or Periapt Audio Cables and see if they offer this option.  If not at least look at what they have.
What is your reason for wanting a coiled cable?
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
The current cable I have just gets in the way while moving things around. I thought if I had a coiled cable, it would be less clutter.
the term you should look for, or what I'm entering into google is "coiled 3.5mm trs to 3.5mm trrs cable"
The connection on your headphones is 3.5mm TRRS and the connection on the other end is 3.5mm TRS
I don't know if it needs to be wired a certain way but that's a start.  It doesn't need to be Sennheiser brand.
I would e-mail either of those companies and ask them if they know of a product or know what you would be looking for.  They are very helpful
DAC S.M.S.L SU-9
Sennheiser uses 2.5mm TRRS wired differently from "normal" balanced 2.5mm TRRS wiring (tip=L+, ring1=R+, ring2=L-, sleeve=R-).
IMO this is kind of stupid from Sennheiser since they don't provide any balanced cables at this price range of headphones. As in, all of the cables for HD 560s have TRS plugs in the other end with the L- and R- wires connected at the plug.
What I would do is open the headphones and solder the L- and R- wires together basicly turning the 2.5mm connector into normal TRS connector and just get either ready made 2.5mm TRS male to 3.5mm TRS male cable (2.5mm->3.5mm AUX cable) or just normal 3.5mm AUX cable and 2.5mm->3.5mm TRS adapter.
