Is it neccesarry to have 2 8pin connectors for a 7950X3D?
Solved by Hinjima,
16 minutes ago, Scrakey said:I recently purchased a BeQuiet! Dark Power 12 1000W together with a Aourus x670e Master motherboard for running a 7950X3D proccessor.
The mobo has 2 8pin connectors for the CPU, but the power supply came with only one 8pin connector and another one which is 10pin but the 2 middle leads are vacant.
Should i purchase from Be Quiet another 8pin connector to occupy the second slot?
Are there any issues doing this?Or can i stick to the single cable?
No, not needed The 1x8 pin will supply more than enough power for the 7950X3D 7950X3D draws around 150w and 1x8 pin CPU is rated for 226w of continous power.
