Questions About Motherboard Dual channel memory.
23 minutes ago, DumbFounded said:Will both black and blue slots gonna add up to 32 gigs of RAM if I fill the black slots with 8 GB's of RAM?
Yes.
23 minutes ago, DumbFounded said:Is buying 2 more 8 GB RAM sticks better than buying x2 16 GB RAM sticks?
It's complicated. Running 4x8GB is a little bit faster than 2x16GB (about 400MT/s worth on DDR4, unless you're buying high-end Samsung B die based memory in which case it's identical), though it's also more likely to run into issues. If you're just at 3200 and assuming you're using a platform with a good memory system, that isn't usually too much of a worry, but if you're on something like 1st gen Ryzen then it's something to be weary about as there's a chance the system won't even boot.
If you don't want to think about it, go 2x16GB especially as the pricing has gotten nearly identical and you can still resell your current kit, though if you buy the kit from somewhere with a good return policy going for an additional 2x8GB isn't the worst idea in the world.
23 minutes ago, DumbFounded said:I heard that people can get BSoD when they use DUAL channel memory.
That's either mixed memory configs or two DIMM per channel configs, not dual channel as you're currently already running dual channel memory. There definitely can be issues, though they aren't exceptionally likely unless you're pushing the limits of the memory system. For reference, each memory channel is actually comprised of a blue slot and a black slot, and having a stick on each channel allows for double the memory throughput.
23 minutes ago, DumbFounded said:Will my PC still be fine if I insert x1 8 GB RAM stick in the black slot?
Yeah, but with how cheap RAM is nowadays I see no reason to not just go for an additional 2x8GB instead.
