I've posted recently about static build killing my laptop.
Apart from the obvious (when I gets back from the shop it's going to live in a different room)
Are there any products that would help it feels like someone should have invented something like a usb cable that just connected to the earth pin on a plug
https://linustechtips.com/topic/1537490-static-build-up/
5 hours ago, saintlouisbagels said:
A cheap humidifier?
I live next to a river it's normally around 70% it's all wooden floors
It's really odd I have a work laptop and a personal one as does my partner
Had a call for the repair shop they can't find a fault they are going to reset the battery (not 100% on what that means assuming it's ether disconnect and reconnect or something else)
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16181640
10 hours ago, james8449834 said:
Like that but attaches to the laptop
that is your power supply/power plug.
The ground plane goes to the ground pin.
Thats why when building a computer, you can just hold onto the PSU plugged into the wall and be grounded.
Ground isn't "real" it's just the Ground reference voltage we call it 0 because it's convenient. Voltage is a delta/difference measure, not an absolute measure of charge. That would be Coulombs.
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16181657
At least in North America, "ground" literally is the ground.
The ground pin on your outlets is tied to a bus bar in your breaker panel, which connects to a wire that attaches to your cold water pipes or an 8 foot long copper rod driven into the dirt.
Neutral also ties into the ground in the panel, but it's also the center tap of the transformer on the street that feeds your house.
Electricity is weird.
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16181825
Thanks for clarifying that I thought it was from the plug to the brick was ground but not from the brick to the device
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16183511
Totally I have a very strong memory of being sat in school had a lesson about electricity and thinking to myself I'm not going to be an electrician so this is not relevant to my. And now I vape.
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16183513
What does the vaping have to do with it?
When you understand electricity, you realize it's AMAZING!
I'm fairly sure static electricity didn't kill your laptop in a 70% humidity home.  Literally impossible to generate static in that much humidity.
Did you drop it or did anything tug on or jack the power cord?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16183617
If you vape nicotine there is a lot of stuff about voltage and resistance that if you understand it it's a lot easier to pick out a vape that works for you
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16183647
Not been droped or had any odd behaviour that would make me think something was about to go. It was not cheap and It's basically my child
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16183648
Was that on carpet or on the wooden floors? If carpet, anti-static versions should solve that https://staticsmart.com/esd-carpet-tile/. Otherwise, get an anti-static mat from GN or someone else. As long as it is grounded, you are grounded and your laptop is grounded to you at least, but should reduce buildup anyways. =x
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16183698
So vaping can kill laptops?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16183710
I think they sent samples out so I can make a little antistatic area
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16183776
Are sure it's not taken a power surge or lightning hit? Hopefully you don't use $12 so called surge protection power strips from Wally World or Amazon.
PRAISE THE LORD AND PASS THE AMMUNITION...
EVGA X299 Dark, i7-9800X, EVGA GeForce GTX 1080 FTW2 SLI
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16184420
7 hours ago, Rocketdog2112 said:
surge protection
useless... i don't even have ground...... no issues.....
18 hours ago, james8449834 said:
No just an a point on why you should listen in school you never know when it might be useful
negative.
the laptop or the vaping?
instructions unclear...
-Scott Manley, 2021
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16184644
That doesn't seem likely I had a baffled call for the repair place Wednesday saying they can't find a fault but he would do some more testing. The repair tracker says it's complete so fingers crossed there will be a full report and it's something else that's been fixed
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16184775
negative.
Troll...
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16184874
4 hours ago, james8449834 said:
What?? Is this aimed at me?
No.
It was intended for this Mark Kaine fellow. Somehow when i quoted him, it came back as if you posted it...
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16185218
7 hours ago, Echothedolpin said:
A but off topic, but vaping near a computer is absolutely is one of the worst things for it.
It leaves thick residue that can short components.
And you have proof of that?
https://linustechtips.com/topic/1537490-static-build-up/#findComment-16186771
