3 pin fan header into 4 pin hub?
By
SillyFrog44
in Cooling
in Cooling
Solved by CWALD,
Just now, SillyFrog44 said:That sounds fine, do you happen to know what pin to leave out then? The 1st or the 4th one i鈥檓 assuming the 4th, but I just wanna double check
It should be keyed so that it only fits one way. On the 4 pin header you will see a tab that is off center and on the 3pin plug there will be a spot to slide over it.
Featured Topics
QMalcolm 路
Posted in General Discussion0 -
FrozenHydrangea 路
Posted in Troubleshooting0 -
LingoInv 路
Posted in Graphics Cards0 -
1
EzioWar 路
Posted in CPUs, Motherboards, and Memory1 -
Zham 路
Posted in Troubleshooting14
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
