There are quite strict rules about how long traces can be between cpu socket (which has the pci-e controller) and the gpu chip, the length of the traces on pci-e 5.0 must be very short.
The riser cable may add too much length or the extra resistance of the wires may degrade the signal enough to just not work at pci-e 5.0 levels.
https://linustechtips.com/topic/1532593-riser-cable/#findComment-16145391
if your motherboard is 5.0, the gpu is 4.0, and the riser is 4.0, there shouldnt be any issue, because the gpu will negotiate 4.0 anyways.
however, if your motherboard and the gpu both are 5.0, and the riser is 4.0, the gpu will try to negotiate 5.0, and you might have rather severe signal problems over the 4.0 riser. so inthat case, you'd have to set that to 4.0 manually.
https://linustechtips.com/topic/1532593-riser-cable/#findComment-16145432
