CPU + GPU TEMPS and possible additional fans
Solved by RONOTHAN##,
14 minutes ago, alvez said:Maybe I will just be spending money for a littel improvment right?
Honestly it's more for aesthetics that anything, there will be no performance benefit and I'd guess you'd get maybe a 2-3C improvement at most (my room temp fluctuates more than that throughout the day). That money would probably be better spent on games or other system accessories than fans if these are the temps.
14 minutes ago, alvez said:Also when I mean under load, I mean while gaming. Still good?
I mean, it depends on the game, but for most yeah, ~60C on the 4070 and ~70C on the 5800X3D is very good. Anything under 70C and 80C respectively in games I'd consider good and not worth improving, and you're well beyond that point.
