Is 6-pin fan connector compatible with 4-pin PWM fan?
5 minutes ago, SecretX said:Since all front fans of my PC case have died, I'm ordering some Noctua PWM fans (A12), and with those I would like to use a fan controller to be able to manually control their speed (so I can do things such as turn them off at night when I go to sleep, reduce their speed when I'm working, and increase it when I'm playing games, etc).
So, in this saga of searching for a fan controller, I found some cheapo fan controllers that have 6-pin fan connectors, like this and this, but I'm not sure if these 6-pin connectors are compatible with PWM 4-pin connector.
So guys, do anybody here know if these cheapo fan controllers work with PWM fans?
PS.: I have a "plan B" controller (this), which have 4-pin connectors, and would, after some "adaptation", fit in my computer case' front panel, but I prefer using a remote control to control my fans, even at expense of not being able to adjust their speed individually.
Those are RGB controllers not fan controllers, well they are but for RGB only, no power delivery.
