how to safely remove battery cells from powerbank?
2 minutes ago, Paingamesyt said:Does this mean i go first + to cut then -聽
it doesnt matter, as long as you mke sure to cut one, then cut the other. it was more meant as a "dont cut both simultaniously" thing initially.
2 minutes ago, Paingamesyt said:The battery have 2.7v
that's not a good sign.. that's WAY low for it to be settled down at.聽 you're probably dealing with some very deteriorated cells here, so they may not even be worth salvaging for other projects.
4 minutes ago, Paingamesyt said:聽Also do i cut the 3 connection where are 3 battery connected at - side.聽
just cut the ties between the cells and the circuit board one at a time, make sure not to short out the wires to the sides of the cells (if you're using sharp snips, they'll poke right trough the plastic protecting the cells), and make sure nothing wil touch what it shouldnt after you're done snipping them off.
