My PC is running crazy (crashes, BSOD, WHEA ERROR)
Solved by predestruction,
Alrighty a small Update Guys:
After figuring and testing out more, i found out that the Cablemod Cables are the likely Reason for the Crashing.
I figured out the biggest difference between the 970 and the 3080 was the Power draw. So i manipulated the Power Target in Afterburner while Running the OCCT Power Test.
At about 70% the PC was crashing. Also touching the Cables of the GPU was resulting in an immediat Crash. Thats why i replaced the Cables with the Factory Cables from Seasonic. Now i made multiple Stress tests and everything is going fine. So all this shit happened just because of the PCIE Cables. The last thing i tought could brake in a PC.
