PVE stops responding, hardware is stable, nothing gets logged. IO related issues?
Solved by leadeater,
3 hours ago, Levent said:moved the adapter to the top pcie1x slot. I ran my cache worker non-stop overnight, I also did couple of terribly long disk benchmarks while scrubbing HDDs. It didnt crash at all.
Top one 100% is off the CPU btw and the bottom one is off the chipset. Sounds like it wasn't happy running off the chipset. Personally quite hopeful that it has fixed the issue.
