Please help! augh, virus?
Go to solution Solved by jettonx,
reformatted. :(
I left my girlfriend to go on my PC, she followed a popup which said my flash was out of date and now my PC freezes on boot.
the program she down loaded was simply called Setup.exe, through Chrome downloads I followed the file to "downloadmediaconverterfree.com"
my AV didn't pick it up, windows recovery did nothing and so did restore,
please advise?
SET UP:
Corsair Vengeance C70 | ASUS Sabertooth Z77 | Intel Core i7 3770k | STOCK COOLER  :( soon to be replaced with a H220! | EVGA 660ti FTW ed. 2GB | 16gb Corsair Vengance 1600Mhz | Corsair 120GB Neutron GTX SSD | 2TB Seagate Barracuda | Corsair AX860i | Corsair AF120 QE X4
https://linustechtips.com/topic/15202-please-help-augh-virus/
yeah, sounds like a virus. Scan your PC on viruses. If AVG can't help try another antivirus, for example Avast free
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169728
I can't even start in safemode without it either freezing or BSOD
SET UP:
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169733
If you can't boot in safemode I don't know what to do. However, try booting into safemode with network and download Malwarebyte's Anti-Malware and run it. It should take care of everything.
I don't know if this can be done at all but is there a way to scan the HDD without booting up..?
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169743
Boot into safe mode with networking> Install malware bytes > Run the program (this should get rid of the virus).
Report back to base camp with your results :)
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169745
Do you have a second computer? Does your current computer have a DVD drive?
If yes to both, download and burn a copy of Hiren's boot CD, then use that to boot. It comes with a few different AVs and you can do scans or import important files to a USB threw it.
P.S. even if your computers don't have a disc drive, you can make a bootable USB but its a bit more painful to do
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169746
Can you burn windows into another temporary hard drive and use that to boot? I don't know how well it will work though.
•  i7 4770k @4.5ghz 1.248v • Noctua NHD14  •  ASUS MAXIMUS VI Hero •  Asus STIRIX 980 Ti •
•  Corsair Vengeance Pro 16Gb  •  Samsung 840 250gb + Samsung 1TB 7200RPM •  BenQ XL2430T 144Hz  •
•  Fractal Design R4  •  CoolerMaster GX650 80+ •  Razer Deathadder Chroma  •  Filco Ninja 2 Red  •  HD600/HE-4/ Fiio E17  •
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169764
Try to find the file and then go to Safe Mode with Command Prompt. Then delete the file there and you should be good to go. It worked for me.
How would I go about doing that?
SET UP:
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169786
Managed to get malware bytes installed, freezes while scanning. Ffs
SET UP:
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169842
I highly suggest you try this http://www.hiren.info/pages/bootcd
15" MBP TB
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169850
Sounds like your girly friend snagged a virus. Can you get an MalwareBytes DVD? Boot off of that and then scan your hard drive.
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169852
i would agree, this is a amazing program
burn it to a cd, boot from cd, then it already has the programs installed, so all you need to do is just find it and scan for the virus, it has just about every program needed
i always had trouble finding the download link in the above address so i normally use this site http://www.hirensbootcd.org/download/
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169898
I know, it has I think seven anti viruses or something, it's perfect! Saved my ass a few times.
15" MBP TB
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169901
What he said, if non of the anti-virus software works in this then you are going to have to wide your drive and do a clean install my friend...
PROFILEYEAH
What do people even put in these things?
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169911
there is one other way of doing it, alot of the time someone else has had the same virus and they have found the file, im sure if the virus scanners all fail, he can try searching google, for what he did and see if people found the file that needs to be deleted, then he can boot from the CD and delete it, but if the virus scanners dont pick it up, i would recommend reinstalling anyway
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169923
These are all good options but without being able to boot I can't burn anything to disk? I'm posting via mobile
SET UP:
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169929
Use the windows disk and chose to repair, it will make a restore point,which should then let you into windows in order to scan for viruses.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169933
I've already done this, no good.
SET UP:
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169945
Damn :( thought it would be worth a try, the other night I got, that FBI detection Virus,it would not let me boot in any of the safe modes, and that is how it says to get read of it, so then I got the idea to put in the windows disk and make a restore point, that did the trick,it allowed me to get to the desktop and run scans with Mal ware and hit man pro. damn other then that you just might have to reformat if it refuses to let you in windows :(
https://linustechtips.com/topic/15202-please-help-augh-virus/#findComment-169956
